Jabra Evolve 20 SE Mono MS USB Headset
£36.16
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Flexible connectivity using USB or jack
  • Manage calls easily with call control unit to make, take and mute calls
  • Plug-and-play connectivity for quick and easy setup
  • All-day comfort with leather-feel ear cushions, and on-the-ear design for all-day use
  • Certified Skype for Business for simple UC integration and plug-and-play straight out of the box
  • Recommended Use: Phone, Phone
  • Connectivity: Wired
  • Stock Status: In Stock
Product codes
Professional headset with easy call management and great sound for calls and music!
More than headsets, a workplace evolution
With great sound for calls and music, the Evolve 20 and 20 Special Edition are entry-level professional headsets with easy call management through a control unit that makes, takes and mutes calls. Simple connectivity makes it easy to get started with your PC.
Clearer conversation for greater efficiency
Entry-level professional headset with easy call management and great sound for calls and music.
Manage calls easily
Get easy access to the most used functions, like volume and mute. You can also answer and end calls quickly and easily, directly from the control unit.
Flexible Plug and Play connectivity
Works straight out of the box. Installation is as easy as simply plugging it in to the USB port on your laptop.
All day comfort (Evolve 20SE)
Built for style and comfort with soft leatherette ear cushions. Adjustable headband lets you find the perfect fit.
Product Description Jabra Evolve 20 MS mono - Special Edition - headset
Product Type Headset - wired
Recommended Use Phone
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Mono
Microphone Boom
Controls Mute, volume, answer/end
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra Evolve 20 SE Mo...
£36.16
