Jabra Evolve 30 Duo MS USB Headset
£64.53
Delivery:
Key features
  • Flexible connectivity using USB or jack
  • Manage calls easily with call control unit to make, take and mute calls
  • Plug-and-play connectivity for quick and easy set-up
  • Leather-feel ear cushions and around-the-ear design for all-day use
  • Certified Skype for Business for simple UC integration for plug-and-play straight out of the box
Product codes
The Jabra Evolve 30 is a professional headset, designed to improve conversations. Excellent speakers are built for both voice and music. Switch easily between conversations and listening to your favorite tracks. Simply wear the headset to eliminate high-frequency noise, such as human voices, - all thanks to the specially designed ear cushions. In-line call controller gives you easy access with large buttons and LED indicators. Pick up or end calls, control volume, or simply mute the line.
Jabra Evolve 30 with 3.5 mm jack
In response to popular demand, Jabra is proud to announce the new upgraded Jabra Evolve 30 now with a new USB call control unit with integrated 3.5 mm jack for connectivity to smart devices.
Help your customers speed up their UC adoption with the user friendly Jabra Evolve 30.
Product Description Jabra Evolve 30 II MS stereo - headset
Product Type Headset - wired - USB, 3.5 mm jack
Recommended Use Portable electronics, computer - communication
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Stereo
Sound Effects Crystal Clear
Audio Specifications Frequency Response 150 - 7000 Hz - Sensitivity 93.6 dB
Impedance 32 Ohm
Max Input Power 10 mW
Microphone Boom
Microphone Technology Electret condenser
Microphone Active Noise Cancelling Yes
Controls Mute, volume, answer/end
Software Certification Certified for Skype for Business
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra Evolve 30 Duo MS...
£64.53
