The Jabra Evolve 40 MS Duo is a professional headset designed to improve concentration and conversations. Premium noise cancellation technology gives you peace to work in a noisy, open office; effectively creating a concentration zone around you so you can stay focused.
The Evolve 40 is a headset featuring amazing sound for calls and music, and an integrated busy-light to enhance your productivity by notifying colleagues that you are busy - therefore allowing you to avoid interruptions in the open office. Connect the headset using a USB or jack. Leather ear cushions allow for all-day comfort.
Microsoft Lync optimized with USB adapter with 3.5mm jack incorporated into the control unit allows you to easily connect your headset to your PC, smartphone and tablet. Busy light signals user availability. Microphone boom arm can be integrated into the headband when not on a call or simply listening to music. Built for style and comfort with leatherette ear cushions. Soft pouch included.
Intuitive Control Unit
Get easy access to the most used functions, such as volume and mute. You can also answer and end calls directly from the control unit.
Plug-and-play set up
Works out of the box with all leading systems. Installation is as easy as simply plugging it in.
Works will all mobile devices
The 3.5 mm jack lets you connect to a PC, smartphone, tablet or any other personal device.
Made for voice and music
World-class speakers are built for both voice and music. Switch easily between conversations and listening to your favourite tracks.
Product Description | Jabra Evolve 40 MS stereo - headset | Product Type | Headset - wired - USB, 3.5 mm jack | Recommended Use | Portable electronics, computer - communication | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Stereo | Sound Effects | PureSound | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 93.6 dB | Impedance | 32 Ohm | Max Input Power | 10 mW | Microphone | Boom | Controls | Mute, volume, answer/end | Software Certification | Certified for Skype for Business | Manufacturer Warranty | 2-year warranty |
Customer return - item has been opened but is in excellent condition
Ref: 9TBX 046326 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046329 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046330 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046333 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046334 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046335 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046336 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046337 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046338 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046339 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046341 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046342 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046343 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046344 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046345 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046346 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046347 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046348 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046349 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046351 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046352 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046353 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046354 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046355 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046356 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046357 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046358 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046359 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046360 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046361 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046362 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
Ref: 9TBX 046363 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
