Jabra Evolve 40 Mono UC USB Headset
£77.28
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Stay in the zone and avoid interruptions, integrated busylight notifies colleagues to avoid interruptions
  • Find inspiration between calls, enjoy your music with amazing sound throughout the day
  • Flexible connectivity, connect using USB or jack
  • All-day comfort and leather-feel ear cushions and on-the-ear design for all-day use
  • Works with all leading UC platforms and certified for Skype for Business, Cisco and more
  • Recommended Use: Computer, Portable electronics
  • Connectivity: Wired
  • Earcover : Monaural
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £80.77
Save £1.50
The Jabra Evolve 40 MS Duo is a professional headset designed to improve concentration and conversations. Premium noise cancellation technology gives you peace to work in a noisy, open office; effectively creating a concentration zone around you so you can stay focused.
The Evolve 40 is a headset featuring amazing sound for calls and music, and an integrated busy-light to enhance your productivity by notifying colleagues that you are busy - therefore allowing you to avoid interruptions in the open office. Connect the headset using a USB or jack. Leather ear cushions allow for all-day comfort.
Microsoft Lync optimized with USB adapter with 3.5mm jack incorporated into the control unit allows you to easily connect your headset to your PC, smartphone and tablet. Busy light signals user availability. Microphone boom arm can be integrated into the headband when not on a call or simply listening to music. Built for style and comfort with leatherette ear cushions. Soft pouch included.
Intuitive Control Unit
Get easy access to the most used functions, such as volume and mute. You can also answer and end calls directly from the control unit.
Plug-and-play set up
Works out of the box with all leading systems. Installation is as easy as simply plugging it in.
Works will all mobile devices
The 3.5 mm jack lets you connect to a PC, smartphone, tablet or any other personal device.
Made for voice and music
World-class speakers are built for both voice and music. Switch easily between conversations and listening to your favourite tracks.
Product Description Jabra Evolve 40 UC mono - headset
Product Type Headset - wired - 3.5 mm jack
Recommended Use Portable electronics, computer - communication
Headphones Form Factor On-ear
Connectivity Technology Wired
Sound Output Mode Mono
Sound Effects PureSound
Audio Specifications Frequency Response 20 - 20000 Hz - Sensitivity 93.6 dB
Impedance 32 Ohm
Max Input Power 10 mW
Microphone Boom
Controls Mute, volume, answer/end
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra Evolve 40 Mono U...
£77.28
