We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Jabra Evolve 65 MS stereo is a professional headset designed to improve concentration and conversations. Premium noise cancellation technology gives you peace to work in a noisy, open office; effectively creating a concentration zone around you so you can stay focused.
Microsoft Lync optimized. Wireless Bluetooth technology gives you up to 30 meters / 100 feet of hands-free connectivity to PC, smartphone and tablet. Up to 10 hours battery life eliminates battery concerns. Simply tap to connect devices with NFC. Dual connectivity enables you to connect your headset to your PC and one other Bluetooth device at the same time, so you can take the call on your preferred phone device. Busy light signals user availability. The microphone boom arm can be integrated into the headband when not on a call. Microphone mute on boom arm. Built for style and comfort with leatherette ear cushions. Soft pouch included.
CHARGE AND STORE
The Evolve 65 now comes with an optional charging stand, providing easy and convenient charging and storage at your desk. The Evolve 65 headset can also be charged without the stand, via the USB cord provided in the box, connected to your PC.
ULTIMATE NOISE CANCELLATION
State-of-the-art noise-cancelling microphone eliminates background noise. You and your conversation partner won't struggle to hear each other.
LONG WIRELESS RANGE
Walk up to 30 meters (100 feet) away from your desk while on a call. You're free to roam around the office to grab a coffee, find documents and multitask. Near Field Communication (NFC) allows you to simply tap your compatible smart device and Jabra Evolve 65 together, and you will be ready to talk or stream music instantly.
INTEGRATED BUSY LIGHT
The Jabra Busy light helps you to cope with the challenges of an open office environment and let people clearly know that you are on the phone. The indicator turns red when you are on a call and keeps you from being interrupted.
Product Description | Jabra Evolve 65+ UC mono - headset | Product Type | Headset - Bluetooth - wireless - NFC - USB | Recommended Use | Portable electronics, computer - communication | Headphones Form Factor | On-ear | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Headphones Technology | Dynamic | Bluetooth Version | Bluetooth 4.0 | Sound Output Mode | Mono | Sound Effects | PureSound | Audio Specifications | Frequency Response 20 - 20000 Hz | Max Input Power | 10 mW | Microphone | Boom | Controls | Volume, mute button, answer/end | Manufacturer Warranty | 2-year warranty |
General | |
Width | 5.86 cm |
Depth | 15.44 cm |
Height | 17.04 cm |
Weight | 79 g |
Earpad Material | Leatherette |
Max Operating Distance | 30 m |
Audio Output | |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio Gateway Hands-Free Profile (AGHFP) |
Frequency Response | 20 - 20000 Hz |
Diaphragm | 28 mm |
In-Cord Volume Control | Yes |
Adjustable Headband | Yes |
Simultaneously Connectable Devices Qty | 2 |
Features | Busy light |
Microphone | |
Type | Boom |
Form Factor | Headset microphone |
Audio Input Details | Uni-directional |
Remote Control | |
Connections | |
Connector Type | Headset (4 PIN USB Type A) |
Miscellaneous | |
Included Accessories | Carrying pouch, charging stand, Jabra Link 370 USB Adapter |
Cable Details | USB cable - detachable |
Compliant Standards | Plug and Play, IC, FCC, KCC, TELEC, SRRC, NCC, RCM |
Power | |
Battery | Headset battery rechargeable |
Run Time (Up To) | 10 hour(s) |
Standby Time | 360 hours |
Recharge Time | 2 hour(s) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 18.1 cm |
Shipping Depth | 21 cm |
Shipping Height | 5.3 cm |
Shipping Weight | 282.1 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
