Jabra Evolve 75 Stereo MS Wireless Headset
FREE DELIVERY
£191.14
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Crystal-clear sound for outstanding calls and music, with world-class speakers and HD voice
  • The freedom to move with dual Bluetooth connectivity to two devices, and a range of 100ft/30m from your connected device
  • All-day comfort from leather-feel ear cushions and on-the-ear design
  • Works with all leading Unified Communication platforms, and is optimized for Skype for Business, Cisco, and more
  • Crystal-clear sound for outstanding calls and music, with world-class speakers and HD Voice
  • Reduce noise and interruptions with active noise-cancellation and integrated busylight
  • The freedom to move with dual Bluetooth connectivity to two devices and a range of 30 m from your connected device
  • Works with all leading Unified Communication platforms, and is optimised for Skype for Business, Cisco and more
  • Recommended Use: Computer, Portable electronics
  • Connectivity: Wireless
  • Stock Status: In Stock, Used Stock
Product codes
Documents
The best wireless headset for concentration in the open office
Block out noise and interruptions in the open office and stay focused on your tasks. Our professional wireless headset delivers amazing sound and superior Active Noise Cancellation.
The Evolve 75 is a wireless headset with superior Active Noise Cancellation and integrated busylight to enhance your productivity. Dual connectivity to two Bluetooth® devices allows you to take calls and listen to music from the same headset, giving you extra freedom to move 100ft/30m away from your smartphone and/or PC.
Outstanding sound for calls and music
HD voice for your calls and world class speakers for music.
Superior ANC and integrated busylight acting as a do not disturb signal
More freedom
Dual Bluetooth® connectivity to two devices at the same time for calls and music, with the flexibility to move up to 100feet/30 meters away from your connected device.
Wireless Bluetooth technology gives you up to 30 meters / 100 feet of hands-free connectivity to PC, smartphone and tablet. Up to 10 hours battery life eliminates battery concerns. Simply tap to connect devices with NFC. Dual connectivity enables you to connect your headset to your PC and one other Bluetooth device at the same time, so you can take the call on your preferred phone device. Busy light signals user availability. The microphone boom arm can be integrated into the headband when not on a call. Microphone mute on boom arm. Built for style and comfort with leatherette ear cushions. Soft pouch included.
Product Description Jabra Evolve 75 MS Stereo - headset
Product Type Headset - Bluetooth - wireless - USB
Recommended Use Portable electronics, computer - communication
Headphones Form Factor On-ear
Connectivity Technology Wireless
Wireless Technology Bluetooth
Bluetooth Version Bluetooth 4.2
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz
Active Noise Canceling Yes
Microphone Boom
Microphone Active Noise Cancelling Yes
Microphones Included 4
Controls Mute, volume, on/off, answer/end
Software Certification Certified for Skype for Business
Resources
The following resources are available for the Jabra Evolve 75 Stereo MS Wireless Headset
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: CWNP 040626
£75.04
product
Ref: CWNP 040626
Accessories
Packaging
Functional
Software
Manuals
£75.04
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra Evolve 75 Stereo...
£191.14
