Jabra Evolve 80 Duo UC USB Headset
£226.28
18 in stock
Delivery:
Standard: 1-3 working days
Key features
  • More concentration, greater productivity, shield disruptive background noise with superior active and passive noise-cancellation for crystal-clear calls and music
  • Stay in the zone and avoid interruptions, superior ANC and an integrated busylight that notifies colleagues to avoid interruptions
  • Find inspiration in sound, immersive music experience delivered by world-class speakers in a premium around-the-ear headset
  • All-day comfort, leather-feel ear cushions and around-the-ear design for all-day use
  • Works with all leading UC platforms and certified for Skype for Business, Cisco and more
  • Recommended Use: Computer, Portable electronics
  • Connectivity: Wired
  • Earcover : Binaural
  • Stock Status: In Stock
Product codes
MORE THAN HEADSETS, A WORKPLACE EVOLUTION
Jabra Evolve 80 is a professional headset that eliminates noise and helps you get in your concentration zone and focus. With smartphone connectivity you can take your concentration zone wherever you are going; work, at the office, at home, travelling or commuting. For calls or simply enjoying music.
UNRIVALLED NOISE CANCELLATION
Built to eliminate noise, Jabra's unique Active Noise Cancellation (ANC) filters out low-frequency background noise. Unique designed ear cushions block high-frequency sounds so you can enjoy your music or phone calls without distraction. Noise-cancelling microphone makes sure that you and the other party can hear each other loud and clear.
SIMPLE PLUG-AND-PLAY SETUP
Works straight out of the box with all leading UC systems. Installation is as easy as simply plugging it Into the USB port or 3.5mm jack to your laptop, or by using the 3.5mm jack straight into your smart device.
INTUITIVE CONTROL UNIT
Get easy access at your fingertips to the most used functions, like accept call, volume and mute.
SIGNAL YOUR AVAILABILITY
Whether you are on a call or working on a task needing your full attention, the Jabra EVOLVE™ 80 has an integrated busy light on the ear cups, letting people around you clearly see your availability. You can activate the red busy light to create your own concentration zone and keep you from being disturbed whenever equired. Evolve 80 makes a great travelling companion too in noisy airports and public environments for phone calls or for music and relaxation. You can take your concentration zone wherever you need to go.
Product Description Jabra Evolve 80 UC stereo - headset
Product Type Headset - wired - 3.5 mm jack
Recommended Use Portable electronics, computer - communication
Headphones Form Factor Full size
Foldable Yes
Connectivity Technology Wired
Headphones Technology Dynamic
Sound Output Mode Stereo
Sound Effects PureSound
Audio Specifications Frequency Response 20 - 20000 Hz
Max Input Power 30 mW
Active Noise Canceling Yes
Microphone Boom
Controls Mute, volume, answer/end
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra Evolve 80 Duo UC...
£226.28
