Jabra Evolve2 85 USB-A MS Stereo Headset with Desk Stand - Black
£384.43
18 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Hear yourself think
  • Don't hide when you're in your stride
  • Bigger speakers
  • It's your call
  • Long week
  • Upgrade to business class
  • Recommended Use: Portable electronics, Computer
  • Connectivity: Wired, Wireless
Product codes
They set out to create instant quiet, anywhere. The result is a world-class professional headset with cutting-edge digital hybrid Active Noise Cancellation(ANC), powered by the most advanced digital chipset ever, and designed for incredible noise isolation; just put it on for instant immersion in your thoughts. It's time to change the game. Welcome to the new standard.
They've taken busylight to a whole new level, making it visible from any direction. The red light is automatically activated when you're on a call or in a meeting, or you can activate it yourself at the touch of a button. So, even when you're right in the middle of everything, your busylight will protect you from all angles, and all interruptions. It's like having a built-in security guard for your concentration.
They've built this headset with powerful leak-tolerant 40mm speakers. Factor in advanced digital chipset and the latest AAC codec, and your music will be sounding better than ever. Good things come to those who wait. This is the audio experience you've been waiting for.
They know that being heard and understood with absolute clarity keeps your calls seamless and professional. So, they took the incredible call performance of world-leading Evolve Series, and they made it even better by building in 10 microphones(yes, 10), powered by that advanced digital chipset they keep talking about, for outstanding call quality, every time. Because when you're making an important call, clarity is everything.
When you finally find a headset that you just can't do without, it's good to know you don't have to. They've used the advanced battery efficiency technology to squeeze every last minute of juice out of this powerful headset.
They took biometric measurements of hundreds of heads to create a perfect design that adjusts to fit every size and shape. Then, they added soft memory foam ear cushions to make it supremely comfortable; so comfortable, you'll forget it's even there. Finally, they assembled it using durable, premium materials. It's comfort that's in a class of its own.
Move seamlessly from the office to on-the-go, with a contemporary casual design and a discrete hidden boom arm that still guarantees exceptional professional sounding calls, even when tucked away. So when you're on the go, only you'll know you're working.
Product Description Jabra Evolve2 85 MS Stereo - headset
Product Type Headset - Bluetooth - wireless, wired - 3.5 mm jack
Compatibility iPhone, Android phone, Mac, Windows
Recommended Use Portable electronics, computer - communication
Additional Functions DSP
Colour Black
Headphones Form Factor Full size
Connectivity Technology Wireless, wired
Wireless Technology Bluetooth
Bluetooth Version Bluetooth 5.0
Sound Output Mode Stereo
Audio Specifications Frequency Response 20 - 20000 Hz - Sensitivity 117 dB
Max Input Power 50 mW
Active Noise Canceling Yes
Noise Isolating Noise isolating
Microphone Boom
Controls Volume, mute button, answer/end, play/pause, next/previous track, voice assistant
Software Certification Certified for Microsoft Teams
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£384.43
