We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
They set out to create instant quiet, anywhere. The result is a world-class professional headset with cutting-edge digital hybrid Active Noise Cancellation(ANC), powered by the most advanced digital chipset ever, and designed for incredible noise isolation; just put it on for instant immersion in your thoughts. It's time to change the game. Welcome to the new standard.
They've taken busylight to a whole new level, making it visible from any direction. The red light is automatically activated when you're on a call or in a meeting, or you can activate it yourself at the touch of a button. So, even when you're right in the middle of everything, your busylight will protect you from all angles, and all interruptions. It's like having a built-in security guard for your concentration.
They've built this headset with powerful leak-tolerant 40mm speakers. Factor in advanced digital chipset and the latest AAC codec, and your music will be sounding better than ever. Good things come to those who wait. This is the audio experience you've been waiting for.
They know that being heard and understood with absolute clarity keeps your calls seamless and professional. So, they took the incredible call performance of world-leading Evolve Series, and they made it even better by building in 10 microphones(yes, 10), powered by that advanced digital chipset they keep talking about, for outstanding call quality, every time. Because when you're making an important call, clarity is everything.
When you finally find a headset that you just can't do without, it's good to know you don't have to. They've used the advanced battery efficiency technology to squeeze every last minute of juice out of this powerful headset.
They took biometric measurements of hundreds of heads to create a perfect design that adjusts to fit every size and shape. Then, they added soft memory foam ear cushions to make it supremely comfortable; so comfortable, you'll forget it's even there. Finally, they assembled it using durable, premium materials. It's comfort that's in a class of its own.
Move seamlessly from the office to on-the-go, with a contemporary casual design and a discrete hidden boom arm that still guarantees exceptional professional sounding calls, even when tucked away. So when you're on the go, only you'll know you're working.
Product Description | Jabra Evolve2 85 MS Stereo - headset | Product Type | Headset - Bluetooth - wireless, wired - 3.5 mm jack | Compatibility | iPhone, Android phone, Mac, Windows | Recommended Use | Portable electronics, computer - communication | Additional Functions | DSP | Colour | Black | Headphones Form Factor | Full size | Connectivity Technology | Wireless, wired | Wireless Technology | Bluetooth | Bluetooth Version | Bluetooth 5.0 | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz - Sensitivity 117 dB | Max Input Power | 50 mW | Active Noise Canceling | Yes | Noise Isolating | Noise isolating | Microphone | Boom | Controls | Volume, mute button, answer/end, play/pause, next/previous track, voice assistant | Software Certification | Certified for Microsoft Teams | Manufacturer Warranty | 2-year warranty |
General | |
Width | 19.86 cm |
Depth | 7.73 cm |
Height | 16 cm |
Weight | 286 g |
Colour | Black |
Headband Material | Foam, leatherette |
Earpad Material | Leatherette, foam |
Max Operating Distance | 30 m |
Audio Output | |
Bluetooth Audio Codec | AAC |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Phonebook Access Profile (PBAP) |
Noise Isolating | Yes |
Active Noise Cancelling Technology | Hybrid ANC |
Frequency Response | 20 - 20000 Hz |
Sensitivity | 117 dB |
Diaphragm | 40 mm |
Simultaneously Connectable Devices Qty | 2 |
Features | Busy light, SafeTone technology, Jabra Direct |
Microphone | |
Type | Boom |
Form Factor | Headset microphone |
Sensitivity | -35 dBV/Pascal |
Frequency Response | 5 - 20000 Hz |
Remote Control | |
Tracking | |
Sensors | On-ear detection |
Connections | |
Connector Type | Headset (mini-phone 3.5mm) |
Cable | |
Detachable Cable | Yes |
Miscellaneous | |
Included Accessories | Charging stand, carrying bag, Inflight adapter, Jabra Link 380c USB Adapter, 3.5 mm audio cable |
Cable Details | Audio cable - detachable - 1.2 m |
Power | |
Battery | Headset battery rechargeable - Lithium Ion |
Run Time (Up To) | 37 hour(s) |
Run Time Details | Continuous playback: up to 37 hours , Continuous playback (noise cancelling ON): up to 32 hours , Continuous talk: up to 30 hours , Continuous talk (noise cancelling ON): up to 20 hours |
Recharge Time | 2.5 hour(s) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 22.7 cm |
Shipping Depth | 9.2 cm |
Shipping Height | 18.85 cm |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
