Jabra LINK Electronic Hook Switch Adapter Cable
£37.33
Delivery:
Standard: 1-3 working days
Key features
  • MPN: 14201-35
  • Original and authentic, manufacturer made accessory
  • The Jabra LINK 14201-35 enables remote Electronic Hook Switch Control (EHS) with Jabra wireless headsets and the Avaya series 1608, 1616, 9620, 9630, 9640 and 9650
Product codes
Enjoy wireless freedom and get remote call control on your wireless headset from a wide range of Avaya deskphones using an Electronic Hook Switch (EHS) cord. Answer or end calls, mute the microphone and adjust volume when you are away from the desk.
Jabra LINK - electronic hook switch adapter
Electronic hook switch adapter
2 years warranty
Avaya one-X Deskphone Edition 9610, 9620, 9620C, 9620L, 9630, 9630G, 9640, 9640G, 9650, 9650C, 9670G; one-X Deskphone Value Edition 1603, 1603-I, 1603SW, 1603SW-I, 1608, 1608-I, 1616, 1616-I
Customer reviews
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: 84M1 029624
£4.62
product
Ref: 84M1 029624
Accessories
Packaging
Functional
Software
Manuals
£4.62
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra LINK Electronic...
£37.33
