Jabra Pro 920 Wireless Headset - Deskphone Only
£155.70
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Simple deskphone connectivity for an ideal first wireless headset
  • Noise-cancelling microphone and HD Voice deliver better customer conversations
  • All-day use around the office, with 8 hours of battery time and up to 120 metres of range
  • Optimised for use with all leading deskphones
  • Easy to deploy and manage
  • Recommended Use: Corded phone
  • Connectivity: Wireless
  • Earcover : Monaural
  • Stock Status: In Stock
Product codes
Documents
The Jabra Pro 920 headset is a professional wireless headset designed for maximum performance. Now everyone in your office can take advantage of the added productivity and comfort that wireless convenience delivers. Simple, intuitive and high quality, all-in-one wireless solution.
With the DECT wireless technology you get up to 120 metres hands-free communication for your deskphone. Talk for up to 8 hours with no battery life concerns.
Wireless headset range
Bring your conversation to the coffee machine, colleague or private room. The Jabra PRO 900 DECT variants give you the wireless freedom to walk and talk at up to 120 metres of range (or 100 metres for Bluetooth variants).
World-class sound
Lifelike conversations require great, ambient-noise reducing speakers and a noise-cancelling microphone that also avoids air shocks. With Jabra PRO 900, you can get both - and choose between a range of mono and duo variants.
Easy to use with all-day battery
The Jabra PRO 900 is easy to set up and get started. Each headset comes with a pre-connected charging base so you can make calls straight away. With up to 12 hours of battery time, you'll never have to worry about running out.
Product Description Jabra PRO 920 - headset
Product Type Headset - DECT - wireless
Localisation Hong Kong, Singapore, United Kingdom
Headphones Form Factor Convertible
Connectivity Technology Wireless
Wireless Technology DECT
Sound Output Mode Mono
Microphone Boom
Controls Mute, volume, answer/end
Resources
The following resources are available for the Jabra Pro 920 Wireless Headset - Deskphone Only
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra Pro 920 Wireless...
£155.70
