Jabra PRO 9450 Duo Flex Boom Wireless Headset
Key features
  • Increase flexibility by connecting your deskphone and softphone to the headset, with touchpad for easy call management
  • Safeguard calls with Jabra-patented headset-to-base pairing and DECT security certification
  • Outstanding sound all day, with best-in-class noise-cancellation and acoustic protection and up to 150 metres of range and 10 hours of battery time
  • Optimised for use with all leading deskphones and UC platforms
  • SmartSetup wizard guides you through the set-up and connection process
Product codes
The Jabra Pro 9450 duo wireless headset delivers up to 150 metres of range and connects to your mobile, deskphone or softphone. This versatile headset also features a noise-cancelling microphone, acoustic protection and wideband audio quality.
Product Description Jabra PRO 9450 Duo - headset
Product Type Headset - DECT - wireless
Recommended Use Phone, computer
Headphones Form Factor Convertible
Connectivity Technology Wireless
Wireless Technology DECT
Sound Output Mode Mono
Audio Specifications Frequency Response 150 - 6800 Hz
Active Noise Canceling Yes
Microphone Boom
Controls Mute, volume, answer/end
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra PRO 9450 Duo Fle...
