Jabra PRO 9460 Duo Dual Connectivity Wireless Headset with To...
Jabra PRO 9460 Duo Dual Connectivity Wireless Headset with Touchscreen
£253.77
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Increase flexibility by connecting your deskphone and softphone to the headset, with touch screen for easy call management
  • Safeguard calls with Jabra-patented headset-to-base pairing and DECT security certification
  • Outstanding sound all day, with best-in-class noise-cancellation and acoustic protection, flexible boom-arm and up to 150 metres of range and 10 hours of battery time
  • Optimised for use with all leading deskphones and UC platforms
  • SmartSetup wizard guides you through the set-up and connection process
Product codes
Documents
With Jabra PRO 9460 DUO headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, Jabra PRO 9460 DUO is fitted with a flex boom for optimum voice pick-up. Providing sound for both ears, the Jabra PRO 9460 DUO blocks out background noise, making it possible to handle calls calmly and professionally at all times.
Jabra PRO 9460 DUO - headset
Headset - wireless - DECT
Recommended Use
PC multimedia, corded phone
Hong Kong, Singapore, United Kingdom
Headphones Type
Headphone - binaural
Headphones Form Factor
Convertible
Wireless - DECT
Sound Output Mode
Mono
Frequency Response
150 - 6800 Hz
Microphone
Boom
2 years warranty
Resources
The following resources are available for the Jabra PRO 9460 Duo Dual Connectivity Wireless Headset with Touchscreen
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra PRO 9460 Duo Dua...
£253.77
