Jabra PRO 9460 Mono Dual Connectivity NC Wireless Headset
£249.18
Delivery:
Key features
  • Increase flexibility by connecting your deskphone and softphone to the headset, with touch screen for easy call management
  • Safeguard calls with Jabra-patented headset-to-base pairing and DECT security certification
  • Outstanding sound all day, with best-in-class noise-cancellation and acoustic protection, flexible boom-arm and up to 150 metres of range and 10 hours of battery time
  • Optimised for use with all leading deskphones and UC platforms
  • SmartSetup wizard guides you through the set-up and connection process
  • Recommended Use: Computer, Phone, Phone, Portable electronics
  • Connectivity: Wireless
  • Earcover : Monaural
Product codes
Documents
With Jabra PRO 9460 headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, the model is fitted with a flex boom for optimum voice pick-up. Jabra PRO 9460 is a single-ear headset that can be worn hooked over the ear, or on a head or neckband.The device is united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. A SmartSetup wizard on the touch screen helps you connect your phones and choose preferences to get started. Once you're up and running, the screen's colorful icons and intuitive menu system make call-handling a breeze.
Product Description Jabra PRO 9460 - headset
Product Type Headset - wireless - DECT
Recommended Use PC multimedia, corded phone, mobile phone
Localisation Hong Kong, Singapore, United Kingdom
Headphones Type Headphone - monaural
Headphones Form Factor Convertible
Connectivity Technology Wireless - DECT
Sound Output Mode Mono
Frequency Response 150 - 6800 Hz
Microphone Boom
Manufacturer Warranty 2 years warranty
Resources
The following resources are available for the Jabra PRO 9460 Mono Dual Connectivity NC Wireless Headset
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra PRO 9460 Mono Du...
£249.18
