Jabra PRO 9460 Spare Headset
£117.33
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Multiuse connectivity: desk and softphone
  • Touch screen base with SmartSetup wizard
  • Noise-canceling microphone and digital signal processing
  • Wideband sound (150 Hz - 6,800 Hz)
  • Full hearing protection with Jabra SafeTone
  • Up to 150m wireless range
  • Minimal energy-consumption with Jabra IntelliPower
  • Up to 10 hours talk time
  • Recommended Use: Computer, Phone, Phone, Portable electronics
  • Connectivity: Wireless
  • Earcover : Monaural
  • Stock Status: In Stock
Product codes
With Jabra PRO 9460 headset, office staff can answer calls made to either of their phones, even while away from their desks. Specially designed for open plan working environments, the model is fitted with a flex boom for optimum voice pick-up. Jabra PRO 9460 is a single-ear headset that can be worn hooked over the ear, or on a head or neckband.
The device is united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. A SmartSetup wizard on the touch screen helps you connect your phones and choose preferences to get started. Once you're up and running, the screen's colorful icons and intuitive menu system make call-handling a breeze.
Product Description Jabra PRO 9460 Replacement - headset
Product Type Headset - DECT - wireless
Recommended Use Portable electronics, phone, computer - communication
Additional Functions DSP
Headphones Form Factor On-ear
Connectivity Technology Wireless
Wireless Technology DECT
Sound Output Mode Mono
Sound Effects Crystal Clear
Audio Specifications Frequency Response 150 - 6800 Hz - Sensitivity 93 dB
Impedance 32 Ohm
Active Noise Canceling Yes
Microphone Boom
Microphone Active Noise Cancelling Yes
Controls Mute, volume, answer/end
Designed For PRO 9460, 9460 Duo, 9460 Mono, 9460 NCSA
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra PRO 9460 Spare H...
£117.33
