Jabra PRO 9465 Duo Flex-boom NC Headset
£274.46
Delivery:
Key features
  • Connect up to 3 phones to the headset
  • Safeguard calls with Jabra-patented headset-to-base pairing and DECT security certification
  • Outstanding sound, with best-in-class noise-cancellation and acoustic protection, flexible boom-arm, up to 150 metres of range and 10 hours of battery time
  • Optimised for use with all leading deskphones and UC platforms
  • SmartSetup wizard guides you through the set-up and connection process
Product codes
Do you battle against the background noise at work? If you can't get the peace and quiet you need to make important calls, try the Jabra PRO 9465 headset. A series of noise canceling, sound enhancing technologies make this headset ideal for office personnel and specialists working in shared spaces. And thanks to triple connectivity, you no longer have to think about which phone is ringing. Whether a caller is trying to get through on your desk, soft or mobile phone, the call will always come to the same headset. You just tap the talk button and answer.
Product Description Jabra PRO 9465 Duo - headset
Product Type Headset - DECT - wireless
Recommended Use Portable electronics, phone, computer
Localisation United Kingdom
Headphones Form Factor On-ear
Connectivity Technology Wireless
Wireless Technology DECT
Sound Output Mode Mono
Audio Specifications Frequency Response 150 - 6800 Hz
Active Noise Canceling Yes
Microphone Boom
Controls Mute, volume, answer/end
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra PRO 9465 Duo Fle...
£274.46
