Jabra PRO 9470 Mono Triple Connectivity Wireless Headset with...
Jabra PRO 9470 Mono Triple Connectivity Wireless Headset with Touchscreen
£260.61
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect up to 3 phones to the headset
  • Safeguard calls with Jabra-patented headset-to-base pairing and DECT security certification
  • Outstanding sound, with best-in-class noise-cancellation and acoustic protection, flexible boom-arm, up to 150 metres of range and 9 hours of battery time
  • Optimised for use with all leading deskphones and UC platforms
  • Superior comfort with 3 wearing styles - over the head, behind the neck or over the ear
Product codes
Documents
Today's business cards often feature different numbers for desk, mobile and softphone. The result? You find yourself grabbing your mobile just as the caller gives up and tries the desk phone instead! Designed with busy managers and specialists in mind, Jabra PRO 9470 can save you a lot of hassle. Thanks to Multiuse technology, all your phone calls come to the same headset. Just tap the talk button and start talking.The three devices - desk, mobile and softphone - are united by a stylish touch screen base. The base connects to your headset via DECT - a technology characterized by its reliable, long range capabilities - offering a wireless range of up to 150m. Equipped with a SmartSetup wizard, the touch screen helps you connect phones and choose preferences to get started. Once you're up and running, it's colorful icons and intuitive menu system make call-handling a breeze.Several state-of-the-art sound technologies enable the Jabra PRO 9470 to deliver unrivaled call clarity and safety. A dual microphone Noise Blackout system with advanced Digital Signal Processing practically eliminates all background noise, so your voice can always be heard clearly. Wideband quality ensures that the sound you hear is crystal clear, while SafeTone technology protects your hearing.
Jabra PRO 9470 - headset
Headset - DECT - wireless
Recommended Use
Portable electronics, phone, computer
Hong Kong, Singapore, United Kingdom
Headphones Form Factor
Convertible
Wireless
Wireless Technology
DECT
Sound Output Mode
Mono
Audio Specifications
Frequency Response 150 - 6800 Hz
Active Noise Canceling
Microphone
Boom
Controls
Mute, volume, tone, answer/end
2 years warranty
Resources
The following resources are available for the Jabra PRO 9470 Mono Triple Connectivity Wireless Headset with Touchscreen
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra PRO 9470 Mono Tr...
£260.61
