Jabra PRO and GO Busy Light
£29.85
Delivery:
Product codes
Daily distractions and unwanted interruptions in the open office environment result in lost efficiency and poor work quality. The Jabra Busylight 14201-10 is a polite, effective way to let people know you are on the phone. A long cord allows you to place the lightwhere it easily can be seen. The indicator turns red when you are on a call and switches off when you end your call.
  • Dome Shaped light guide makes it visible from all angles
  • 180 degree turntable foot with double adhesive tape allows you to place the Busy Light in a prominant spot
  • Powered via base unit
  • Compatible with PRO9400, Motion Office, LINK850/860 & GN9330 series
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Jabra PRO and GO Busy...
£29.85
