Jabra Stealth UC + MS Lync Bluetooth Headset
£81.10
Delivery:
Standard: 1-3 working days
Key features
  • HD sound with noise reduction
  • Dedicated voice control button
  • Superior comfort in a small design
  • Uncompromising Performance
  • Custom fit for optimal comfort
  • One headset for all your phones
  • Premium sound
  • Recommended Use: Computer, Portable electronics
  • Connectivity: Wireless
  • Earcover : Monaural
  • Stock Status: In Stock
Product codes
Comfortable Bluetooth mono headset with up to 6 hours of talk time. Easily connect with NFC-enabled smartphones by simply tapping the two devices together. Activate Siri or Google Now directly from the headset. Enjoy clear calls with high-definition sound.
Advanced Noise Blackout technology ensures clear, noise-free calls. Dual microphones reduce background noise, making you easy to hear. HD Voice brings high-definition sound quality to both ends of the call.
Stealth delivers superior comfort in a small design. The weight of the headset is perfectly balanced. It's so discreet that you'll hardly notice you're wearing it.
Leave your phone in your pocket. Activate Siri and Google Now by tapping a dedicated button directly on the headset.
Product Description Jabra STEALTH UC (MS) - headset
Product Type Headset - Bluetooth - wireless - NFC
Recommended Use Portable electronics, computer
Headphones Form Factor In-ear - over-the-ear mount
Connectivity Technology Wireless
Wireless Technology Bluetooth
Headphones Technology Dynamic
Bluetooth Version Bluetooth 4.0 EDR
Impedance 32 Ohm
Active Noise Canceling Yes
Controls Volume, on/off, answer/end
Intelligent Assistant Siri, Google Now
Software Certification Certified for Skype for Business
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra Stealth UC + MS...
£81.10
