Jabra Stealth UC Bluetooth Headset
£86.41
Delivery:
Key features
  • HD sound with noise reduction
  • Dedicated voice control button
  • Superior comfort in a small design
  • Uncompromising Performance
  • Custom fit for optimal comfort
  • One headset for all your phones
Product codes
Jabra Stealth, our debut next-generation Bluetooth headset is significantly smaller, lighter, more discreet and offers better comfort and longer talk time.
Advanced Noise Blackout™ technology ensures clear, noise-free calls. Dual microphones reduce background noise, making you easy to hear. HD Voice* brings high-definition sound quality to both ends of the call.
Stealth delivers superior comfort in a small design. The weight of the headset is perfectly balanced. It’s so discreet that you’ll hardly notice you’re wearing it.
Leave your phone in your pocket. Activate Siri and Google Now by tapping a dedicated button directly on the headset.
Stay connected with the nano sized bluetooth dongle
With a UC-compatible dongle, you can transfer calls from your softphone to your smartphone using the Jabra Stealth UC.
Optimised for Microsoft® Lync™, fully UC compatible
Product Description Jabra STEALTH UC - headset
Product Type Headset - Bluetooth - wireless - NFC
Recommended Use Portable electronics, phone
Headphones Form Factor In-ear - over-the-ear mount
Connectivity Technology Wireless
Wireless Technology Bluetooth
Headphones Technology Dynamic
Bluetooth Version Bluetooth 4.0 EDR
Impedance 32 Ohm
Active Noise Canceling Yes
Controls Volume, on/off, answer/end
Intelligent Assistant Siri, Google Now
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Jabra Stealth UC Bluet...
£86.41
