JBL Bar Studio 2.0-Channel Soundbar with Bluetooth
FREE DELIVERY
£149.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • All-in-one soundbar with built-in dual bass port design
  • JBL surround sound
  • Wireless music streaming with Bluetooth
  • HDMI (ARC) connection
  • Works with your TV remote control
  • Audio System Type: Soundbar
  • Surround system: 2.0 Channel
  • Stock Status: In Stock, Used Stock
Product codes
JBL Bar Studio compact soundbar provides stellar sound for your favorite TV series, movies and music. It's slim, incomparably designed and extremely easy to use. JBL surround sound and double bass ports turn your TV sound into real cinema sound. The JBL Bar Studio offers Bluetooth connectivity, so that you can stream your favorite music to the speaker, wirelessly. It is easy to set up with just one single HDMI cable to connect between your TV and the soundbar. You can control the JBL Bar Studio with your existing TV remote control.
Product Description JBL Bar Studio - sound bar - wireless
Product Type Sound bar - 2.0-channel
Enclosure Design Bass reflex
Speaker Type Active
Nominal Output Power 30 Watt
Frequency Response 60 - 20000 Hz
Interfaces Bluetooth
Colour Black
Sound Effects JBL Surround Sound
Dimensions (WxDxH) 61.4 cm x 8.6 cm x 5.8 cm
Weight 1.4 kg
Manufacturer Warranty 1-year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used but is in excellent condition
Ref: FB8M 041328
£53.46
product
Customer return - item has been used and shows signs of use
Ref: FB8M 041217
£43.36
product
Ref: FB8M 041272
£48.12
product
Ref: FB8M 041347
£53.46
product
Ref: FB8M 041328
Accessories
Packaging
Functional
Software
Manuals
£53.46
product
Ref: FB8M 041217
Accessories
Packaging
Functional
Software
Manuals
£43.36
product
Ref: FB8M 041272
Accessories
Packaging
Functional
Software
Manuals
£48.12
product
Ref: FB8M 041347
Accessories
Packaging
Functional
Software
Manuals
£53.46
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
JBL Bar Studio 2.0-Cha...
£149.98
