JBL Bar Studio 2.0-Channel Soundbar with Bluetooth
FREE DELIVERY
£149.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • All-in-one soundbar with built-in dual bass port design
  • JBL surround sound
  • Wireless music streaming with Bluetooth
  • HDMI (ARC) connection
  • Works with your TV remote control
  • Audio System Type: Soundbar
  • Surround system: 2.0 Channel
  • Stock Status: Clearance,
    Used stock also available below
Product codes
JBL Bar Studio compact soundbar provides stellar sound for your favorite TV series, movies and music. It's slim, incomparably designed and extremely easy to use. JBL surround sound and double bass ports turn your TV sound into real cinema sound. The JBL Bar Studio offers Bluetooth connectivity, so that you can stream your favorite music to the speaker, wirelessly. It is easy to set up with just one single HDMI cable to connect between your TV and the soundbar. You can control the JBL Bar Studio with your existing TV remote control.
Product Description JBL Bar Studio - sound bar - wireless
Product Type Sound bar - 2.0-channel
Enclosure Design Bass reflex
Speaker Type Active
Nominal Output Power 30 Watt
Frequency Response 60 - 20000 Hz
Interfaces Bluetooth
Colour Black
Sound Effects JBL Surround Sound
Dimensions (WxDxH) 61.4 cm x 8.6 cm x 5.8 cm
Weight 1.4 kg
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
JBL Bar Studio 2.0-Cha...
£149.98
