Take the party with you no matter what the weather. The JBL Charge 5 speaker delivers bold JBL Original Pro Sound, with its optimized long excursion driver, separate tweeter and dual pumping JBL bass radiators. Up to 20 hours of playtime and a handy powerbank to keep your devices charged to keep the party going all night. Rain? Spilled drinks? Beach sand? The IP67 waterproof and dustproof Charge 5 survives whatever comes its way. Thanks to PartyBoost, you can connect multiple JBL PartyBoost-enabled speakers for a sound big enough for any crowd. With all-new colors inspired by the latest street fashion trends, it looks as great as it sounds.
Product Description | JBL Charge 5 - speaker - for portable use - wireless | Product Type | Speaker - for portable use | Protection | Dustproof, waterproof | Enclosure Design | Passive radiator | Speaker Type | Active | Continuous Power | 40 Watt | Frequency Response | 65 - 20000 Hz | Amplifier | Integrated | Interfaces | Bluetooth | Colour | Black | Power Options | USB charging (powerbank function) | Battery | Speaker battery rechargeable - lithium polymer | Dimensions (WxDxH) | 22.3 cm x 9.4 cm x 9.65 cm | Weight | 960 g |
General | |
Features | PartyBoost |
Enclosure Colour | Black |
Design Features | Rugged |
Speaker System | |
Signal-To-Noise Ratio | 80 dB |
Interfaces | Bluetooth 5.1 |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Speaker System Details | |
Driver Details | Speaker: woofer driver - racetrack , Speaker: tweeter driver , Speaker: 2 x Passive Radiator |
Connections | |
Connector Type | USB (24 pin USB-C) |
Miscellaneous | |
Included Accessories | USB-C cable |
Compliant Standards | IP67 |
Power | |
Power Source | Battery |
Battery | |
Type | Rechargeable - lithium polymer |
Capacity (Ah) | 7500 mAh |
Capacity (Wh) | 27 Wh |
Voltage Provided | 3.6 V |
Run Time (Up To) | 20 hours |
Recharge Time | 4 hours |
Dimensions & Weight | |
Width | 22.3 cm |
Depth | 9.4 cm |
Height | 9.65 cm |
Weight | 960 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
