JBL Go 2 Bluetooth Speaker - Grey
FREE DELIVERY
£29.98
Colours:
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Wireless Bluetooth streaming: stream music wirelessly from any smartphone or tablet
  • IPX7 waterproof: no need to worry about water, the GO 2 can be submerged while playing
  • Speakerphone: built-in echo and noise canceling speakerphone allows for crystal-clear calls
  • Rechargeable battery: built-in rechargeable li-ion battery
  • Aux in connectivity: allows users to also play music with a wired connection
  • Speaker Type: Speaker
  • Connection: Wired, Wireless
  • Stock Status: In Stock
Product codes
The JBL GO 2 is a portable, compact Bluetooth speaker with next-generation audio quality and a bolder design. This next generation of the fan-favorite JBL GO speaker packs a punch, with even more audio output in the same compact palm-sized design. With long-lasting playtime and JBL Signature Sound, coupled with increased audio quality and performance, the JBL GO 2 is the perfect speaker for consumers looking for an easy-to-use, on-the-go music experience.
Making a splash with its waterproof IPX7 design, the JBL GO 2 gives music lovers everywhere the opportunity to bring their speaker poolside, to the beach, or on a porch or patio. For consumers looking for more versatility in a portable speaker, the JBL GO 2 comes equipped with an echo and noise canceling speakerphone. Users can make crystal-clear calls by simply connecting their smartphone via Bluetooth.
Product Description JBL Go 2 - speaker - for portable use - wireless
Product Type Speaker - for portable use
Protection Waterproof
Speaker Type Active
Nominal Output Power 3 Watt
Frequency Response 180 - 20000 Hz
Amplifier Integrated
Interfaces Bluetooth
Speaker Details Speaker - mono - 3 Watt - 180 - 20000 Hz - active
Colour Misty grey
Power Options USB charging
Battery Speaker battery rechargeable - Lithium Ion
Dimensions (WxDxH) 8.6 cm x 3.16 cm x 7.12 cm
Weight 184 g
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
JBL Go 2 Bluetooth Spe...
£29.98
