We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
JBL Go 3 features bold styling and rich JBL Pro Sound. With its eye-catching edgy design, colorful fabrics and expressive details this is a must-have accessory for your next outing. Your tunes will lift you up with JBL Pro Sound, it's IP67 waterproof and dustproof so you can keep listening rain or shine, and with its integrated loop, you can carry it anywhere. JBL Go 3 looks as vivid as it sounds.
Product Description | JBL Go 3 - speaker - for portable use - wireless | Product Type | Speaker - for portable use | Protection | Dustproof, waterproof | Speaker Type | Active | Continuous Power | 4.2 Watt | Frequency Response | 110 - 20000 Hz | Amplifier | Integrated | Interfaces | Bluetooth | Speaker Details | Speaker - mono - 4.2 Watt - 110 - 20000 Hz - active | Colour | Red | Power Options | USB charging | Battery | Speaker battery rechargeable - lithium polymer | Dimensions (WxDxH) | 8.75 cm x 4.13 cm x 7.5 cm | Weight | 209 g | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Colour | Red |
Design Features | Built-in hang loop |
Speaker System | |
Signal-To-Noise Ratio | 85 dB |
Interfaces | Bluetooth 5.1 |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Speaker System Details | |
Speaker Details | Speaker - mono - 4.2 Watt - 110 - 20000 Hz CFR - active |
Driver Details | Speaker: full-range driver |
Connections | |
Connector Type | DC power input (USB Type-C) |
Miscellaneous | |
Included Accessories | USB-C cable |
Compliant Standards | IP67 |
Power | |
Power Source | Battery |
Battery | |
Type | Rechargeable - lithium polymer |
Capacity (Wh) | 2.775 Wh |
Run Time (Up To) | 5 hour(s) |
Recharge Time | 2.5 hour(s) |
Dimensions & Weight | |
Width | 8.75 cm |
Depth | 4.13 cm |
Height | 7.5 cm |
Weight | 209 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
