JBL Live 650 Wireless Over-Ear NC Headphones - Blue
FREE DELIVERY
£151.52
Delivery:
Standard: 1-3 working days
Key features
  • Hands-free calls
  • Multi-point connexion
  • Comfort-fit fabric headband
  • Connectivity: Wireless
  • Colour: Blue
  • Stock Status: In Stock
Product codes
Bundle deals (1)
GOOGLE NEST HUB SMART DISPLAY
= £190.52
Save £40.00
In your world, music is essential, so slip on a pair of JBL LIVE 650BTNC wireless over-ear noise-canceling headphones and elevate your day. Equipped with powerful 40mm drivers, JBL LIVE650BTNC headphones deliver JBL Signature Sound punctuated with enhanced bass so every track on every playlist pops. And when the music is the only thing that matters, the active Noise-Canceling technology allows you to block-out ambient sounds so nothing disturbs your groove. Need some help getting through the day? Easily access the Google Assistant or Amazon Alexa with a tap on the ear cup and play your favorite playlist, text your friend or check the weather and much more, without glancing at your phone. But that's not all. With a cool, lightweight and comfortable design, you'll enjoy up to 30 hours (20 hours with BT + ANC) of music streaming with 2 hours of recharging time, multi-point connection capabilities and a convenient detachable cable with remote/mic, that lets you play on even when the battery goes off. Rock out uninterrupted with the JBL LIVE650BTNC headphones.
Product Description JBL LIVE 650BTNC - headphones with mic
Product Type Headphones - Bluetooth - wireless - 3.5 mm jack
Recommended Use Portable electronics
Colour Blue
Headphones Form Factor Full size
Foldable Yes
Connectivity Technology Wireless
Wireless Technology Bluetooth
Radio Frequency Range 2.402 - 2.480GHz
Bluetooth Version Bluetooth 4.2
Sound Output Mode Stereo
Sound Effects Signature Sound
Audio Specifications Frequency Response 16 - 20000 Hz - Sensitivity 100 dB
Impedance 32 Ohm
Active Noise Canceling Yes
Controls Voice assistant
Intelligent Assistant Siri, Google Assistant, Alexa
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
JBL Live 650 Wireless...
£151.52
