Here at Juice we only use MFI Approved lightning chips, ensuring every one of our cables works perfectly every time.
The Juice Lightning Cable is a must have for all of your iPhone & iPad charging needs. The Juice MFI Approved Lightning charge and sync cable is compatible with all iPhones & iPads.
Product Description | Juice Lightning cable - 1 m | Cable | Lightning cable | Length | 1 m | Colour | White | Connector | Lightning - male | Connector (Second End) | USB - male | Features | Sync and charge | Designed For | Apple 10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; 5; iPad with Retina display; iPhone 11, 5, 5c, 5s, 6, 6s, 7, 8, SE, X, XR, XS, XS Max; iPod nano; iPod touch |
General | |
Cable Type | Lightning cable |
Length | 1 m |
Colour | White |
Connectivity | |
Connector | Apple Lightning - male |
Connector (Second End) | 4 pin USB Type A - male |
Miscellaneous | |
Compliant Standards | MFI |
Dimensions & Weight | |
Weight | 40 g |
Compatibility Information | |
Designed For | Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini (1st generation) , Apple iPad mini 2 (2nd generation) , Apple iPad mini 3 (3rd generation) , Apple iPad mini 4 (4th generation) , Apple iPad mini 5 (5th generation) , Apple iPad with Retina display (4th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod nano (7G) , Apple iPod touch (5G, 6G, 7G) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
