Juice 2m USB-A to USB-C Rounded Cable - White
£14.98
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 2m
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Juice XL USB Type C charge and sync cable
This improved tech allows you to charge and sync your devices faster via USB-C. Plug the USB connector into a charger or computer and the reversible USB-C connector into your device and charge. Reversible connector allows you to plug in your device in any direction.
3 Amp output - improved technology allows faster data transfer (10 x faster than USB 2. 0).
Device compatibility: All devices with USB-C connection: Mobiles, tablets, gaming devices, laptops, hard drives and more, Samsung compatible mobiles and tablets, Huawei compatible mobiles, One Plus compatible mobiles.
Cable Length: 2m
Product Description Juice USB-C cable - 2 m
Type USB-C cable
Features Sync and charge
Length 2 m
Connector 4 pin USB Type A - male
Connector (Second End) 24 pin USB-C - male
Compliant Standards USB 3.1
Colour White
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - shows signs of use. Please note Does not come in original packaging but in a padded envelope.
Ref: FT64 042352
£3.60
product
Ref: FT64 042352
Accessories
Packaging
Functional
Software
Manuals
£3.60
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Juice 2m USB-A to USB-...
£14.98
