Juice Wireless Charger Tile 10W - White
FREE DELIVERY
£14.98
30 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
  • Type: Wireless Charger
  • Stock Status: In Stock
Product codes
Bundle deals (2)
CHARGE YOUR APPLE DEVICE WITH JUICE LIGHTNING CABLE
= £24.97
Save £7.99
CHARGE YOUR DEVICE WITH JUICE USB-C CABLE
= £23.96
Save £4.00
Juice Wireless charging tile is perfect for charging any smartphone with wireless charging capability, including the Samsung S9, S10, or the iPhone X/8.
Introducing the Juice Tile wireless charger. Simply place your compatible device onto the Tile and walk away. In order to use the Juice Tile you will also need a USB wall charger and Micro USB cable.
Typical charging times:
iPhone8 (1. 5hr for 0-50% charge) (3hr for 0-100% charge);
iPhone 8+ (under 2hr for 0-50% charge) (under 4hr for 0-100% charge);
iPhone X (under 2hr for 0-50% charge) (under 4hr for 0-100% charge);
Samsung S8/S9 (80 mins for 0-50% charge) (3hr for 0-100% charge).
Instructions: Connect the cable to the tile, Plug the cable into a wall charger, Place your compatible mobile onto the tile and walk away. At Juice we decided to limit the amount of accessories supplied with our wireless chargers in order to reduce product waste, as we are sure you may already have a micro USB cable and wall charger at home.
Spec
10 Watt wireless charging tile (65 x 10mm)
LED charging lights
Micro USB input
Charges through cases upto 3mm thick
Output: 10W
Input: DC 5V/9V, 18W
Weight: 141g
Product Description Juice Tile wireless charging pad
Product Type Wireless charging pad
Dimensions (WxDxH) 6.5 cm x 6.5 cm x 1 cm
Colour White
Voltage Required DC 5 / 9 V
Voltage Provided DC 5 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Juice Wireless Charger...
£14.98
