Kensington Anti-Glare and Blue Light Reduction Filter for 15....
Kensington Anti-Glare and Blue Light Reduction Filter for 15.6" Laptops
£29.23
Delivery:
Standard: 1-3 working days
Key features
  • Innovative anti-glare coating reduces reflection and improves clarity (matte side only). This filter eliminates harmful blue light by up to 43%, easing eye strain and reducing the chances of interrupting sleep patterns.
  • Antimicrobial coating (matte side only) inhibits bacteria growth by up to 99% (tested to JIS Z 2801 : 2010E for Escherichia coli and Staphylococcus aureus).
  • Seamless attachment makes installation and removal easy and mess-free.
  • Touch and pen enabled, so you can use your device just as you would without a filter.
  • Included cleaning cloth helps keep your screen dust, lint, and smudge-free.
  • Two-year warranty means you can rest assured knowing you're covered by Kensington.
Product codes
Reduce glare and harmful blue light, and improve clarity with Kensington's Anti-Glare and Blue Light Reduction Filter for 15.6" Laptops. This filter reduces harmful blue light by up to 43%, and features an antimicrobial coating (matte side only) that inhibits bacteria growth by up to 99% (tested to JIS Z 2801 : 2010E for Escherichia coli and Staphylococcus aureus). An innovative anti-glare coating (matte side only) reduces reflection and improves clarity. Seamless attachment makes installation and removal easy and mess-free.
Product Description Kensington - notebook privacy filter
Product Type Notebook privacy filter
Installation Type Removable
Package Content Cleaning cloth
Colour Transparent
Product Material PET
Dimensions (WxDxH) 34.5 cm 19.4 cm
Weight 25 g
Display Screen Size Compatibility 15.6" wide
Features Anti-reflective, antimicrobial finish, 3H hard-coating, blue light cutting
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£29.23
