Kensington CA1000 USB-C to USB-A Adapter
£11.25
Delivery:
Standard: 1-3 working days
Key features
  • Halogen-free is safer, RoHS compliant
  • Depending on host device, up to 3 AMPs charge a smartphone or tablet
  • Metal-injection molded connector prevents bending
  • Plug & Play installation
Product codes
The first wave of USB-C products are here and Kensington is making sure you have the adapter to keep your standard USB accessories up and running. The CA1000 USB-C to USB-A Adapter allows you to connect your USB-C device to a keyboard, mouse, hard drive or other peripheral accessory with a standard USB-A port. The adapter has a reversible connector and supports charging up to 3 AMPs. You can also transfer data up to 5 Gbps, and with Plug & Play installation, youll be connected quickly and easily.
Kensington CA1000 - USB-C adapter
USB-C adapter
Molded, sync and charge
Connector
4 pin USB Type A - female
Connector (Second End)
24 pin USB-C - male
USB 3.1
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington CA1000 USB-...
£11.25
