Kensington CH1000 USB-C 4-Port Hub, USB 3.1 Gen
£30.80
Delivery:
Standard: 1-3 working days
Key features
  • Compact design makes the hub highly portable
  • Hub offers 3 USB-A ports and 1 USB-C port for simple device expansion
  • Plug & Play installation with no drivers
Product codes
The CH1000 USB-C 4-Port Hub is the simple, easy way to expand the connectivity of your USB-C device. Connect your peripherals like a mouse, keyboard or flash drive using the three USB-A ports, while using the single USB-C port to connect a smartphone or tablet that features the new style of port. The hub offers USB 3.1 Gen 1 technology, supporting data transfer speeds up to 5 Gbps. With Plug & Play installation, all your accessories will be up and running quickly, and the compact design means it can be easily packed up and taken with you on the road.
Kensington CH1000 - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 1 x USB-C
Google Chrome OS, Windows 8, Windows 8.1, Apple MacOS X 10.10, Windows 10
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington CH1000 USB-...
£30.80
