Kensington ClickSafe 2.0 Keyed Laptop Lock - Security cable -...
Kensington ClickSafe 2.0 Keyed Laptop Lock - Security cable - 1.8m
£39.13
Delivery:
Key features
  • 5mm Keying System is compatible across all of Kensingtons latest locks and includes patented anti-pick Hidden Pin Technology, all part of our robust custom key management solutions that include Master Keyed (K64436M), Supervisor Keyed*(K64436S) and Like Keyed (K64436L) options
  • Carbon steel cable resists cutting attempts and anchors to desk, table or any fixed structure
  • ClickSafe Lock provides one-step security after Security Anchor has been installed into Kensington Security Slot found on most laptops, increasing employee compliance
  • Pivot and rotate cable provides superior laptop engagement
  • Independently verified and tested for industry-leading standards in torque/pull, foreign implements, lock lifecycle, corrosion, key strength and other environmental conditions
  • Register & Retrieve program allows you to order replacement keys
  • Tough yet smaller lock head offers uncompromised security for a wide variety of laptops and devices
Product codes
From the industry leader in physical device security for 25 years, Kensington's ClickSafe 2.0 Keyed Laptop Lock offers all the strength and one-click convenience and keyless engagement of the original, just in a smaller, uncompromised design. Featuring the 5mm keying system with anti-pick Hidden Pin Technology, the ClickSafe lock head snaps onto the ClickSafe Security Anchor after it has been installed into the Kensington Security Slot found in most laptops. A carbon steel cable deters cutting attempts and the pivot & rotate hinge prevents awkward angles when inserting the key.
Kensington ClickSafe 2.0 Keyed Laptop Lock - security cable
Security cable
Product Material
Carbon steel
Length
1.8 m
Pivot adjustment, ClickSafe Security Anchor, cut-resistant, hidden pin, rotatable
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington ClickSafe 2...
£39.13
