Kensington Clicksafe Twin Laptop Lock
£61.42
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Carbon steel cable is cut-resistant and anchors to desk, table or any fixed structure
  • ClickSafe Lock provides one-step security after Security Anchor has been installed into Kensington Security Slot found on most laptops, increasing employee compliance
  • Tamper-resistant, disk-style lock provides near-impenetrable theft protection
  • Give your employees superior and effortless laptop and peripheral accessory security with the ClickSafe Keyed Twin Laptop Lock
  • One-handed engagement without need to use a key
  • Register & Retrieve program allows you to order replacement keys
  • Two lock heads allow you to secure a laptop and a peripheral accessory
  • Device Type: Laptop
  • Type: Security
  • Device Screen Size: [N/A]
  • Stock Status: In Stock
Product codes
The ClickSafe lock has been engineered to deliver strength and ease of use. A keyless locking motion makes the employees role in protecting your business easy. All they have to do is click it on and your business is safe.
Kensington ClickSafe locks are constructed from the strongest materials to deliver the best security available from a cable laptop lock. A high carbon steel cable, all metal lockhead and rigorous real-world testing against lock-picking, corrosion, tampering and for a lifetime in excess of 10,000 key turns means that you can rest assured that ease of use is delivered without jeopardising integral strength.
Quality is ensured by deploying the same manufacturing processes as used for surgical instruments.
Organisations invest in physical security to protect themselves against network attacks, the cost of lost productivity and broken reputations. A physical lock is an investment that pays back every time its used.
Product Description Kensington ClickSafe Keyed Twin Laptop Lock security cable lock
Product Type Security cable lock
Package Content Security cable, 2 x keys
Product Material Steel
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Clicksafe T...
£61.42
