Kensington Combination Ultra Laptop Lock
£32.55
Delivery:
Standard: 1-3 working days
Express: Delivered on Wednesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Carbon steel cable is cut-resistant and anchors to desk, table or any fixed structure
  • Keyless 4-wheel preset number combination
  • Register & Retrieve program allows you to look up forgotten codes
  • Push-button design for one-handed engagement to easily attach lock
  • T-Bar Locking Technology attaches to the Kensington Security Slot found on most laptops
  • Serial number is etched on lock head for easy identification
  • Device Type: Laptop
  • Type: Security
  • Device Screen Size: [N/A]
  • Stock Status: In Stock
Product codes
Protect your laptop and the private information thats on it with the Combination Laptop Lock. The push-button design offers one-handed engagement for easy attachment to any Kensington Security Slot found on most laptops. The lock has a preset combination and a serial number, making it easy for immediate use and easy retrieval of forgotten codes.
Product Description Kensington Combination Ultra Laptop Lock security cable lock
Product Type Security cable lock
Colour Grey
Product Material Plastic, carbon steel
Length 1.8 m
Weight 240 g
Features Wheels, T- bar lock, password lock, 4 digit code
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Combination...
£32.55
