Kensington Duo Gel Mouse Wrist Rest - Black / Purple
£12.69
Delivery:
Standard: 1-3 working days
Key features
  • Duo-tone colour combination
  • Soft finish thats easy to wipe clean
  • Ventilation channel helps keep hands cool and dry
  • Gel pillow matches natural curve of wrist and hand for comfortable scrolling and clicking
  • Stock Status: In Stock
Product codes
The Duo Gel Mouse Pad combines a durable vinyl pad, providing a rigid base for fast and accurate mouse movement, with a wrist rest that moulds itself to your wrist shape for complete comfort and support. Available in a choice of 3 stylish duo-tone colours, it features a ventilation channel to keep hands cool and dry and has an easy wipe-clean finish.
  • Mouse pad features dedicated wrist rest
  • Gel pillow matches natural curve of wrist and hand for comfortable computing
Product Description Kensington Duo Gel Mouse Pad Wrist Rest - mouse pad with wrist pillow
Product Type Mouse pad with wrist pillow
Product Material Vinyl, gel
Dimensions (WxDxH) 18.2 cm x 24 cm x 2.5 cm
Weight 420 g
Colour Black, blue
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Duo Gel Mou...
£12.69
