Kensington Easy Riser Notebook Cooling Stand With Smartfit
£13.82
17 due in 5-7 days
Delivery:
Key features
  • Fits laptops 12" to 17"
  • SmartFit system provides a customised monitor height adjustment in two easy steps
  • Folds flat to travel easily
  • Padded inserts provide a secure, stable fit and keeps your laptops in place
  • Increases air circulation to keep your laptop cooler
  • This product should be used with an external keyboard and mouse (sold separately)
  • Device Type: Laptop
  • Type: Cooling
  • Device Screen Size: [N/A]
  • Colour: Grey, Purple
Product codes
Documents
One size doesn't fit all. When it comes to comfort, fit is everything.
Complying with ergonomic standards doesnt have to be a pain. The Kensington SmartFit system eliminates the complication, confusion and high cost of giving your employees safe, comfortable, ergonomic workstations. Years of research from the US Army revealed a direct correlation between hand size and body measurements. The result is a simple colour-coding system that allows users to adjust for the perfect fit in seconds, every time, leaving you to deal with more important projects.
SmartFit demystifies ergonomics for individuals making it easy to install and customise their workspace accessories to their ergonomic comfort requirements.
Every SmartFit product includes a hand chart in the box. This indicates the specific SmartFit colour setting that will deliver optimum ergonomic comfort for the user.
A small investment in workplace ergonomics can generate significant rewards in productivity by reducing fatigue.
Product Description Kensington Easy Riser notebook stand
Product Type Notebook stand
Notebook Supported Sizes 12" - 17" / 30.5 cm - 43.2 cm
Features Padded
Resources
The following resources are available for the Kensington Easy Riser Notebook Cooling Stand With Smartfit
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Easy Riser...
£13.82
