The Expert Mouse Wired Trackball is the ultimate productivity enhancer that makes working at the desk quicker, more accurate and extremely comfortable for your hand and wrist. Featuring DiamondEye technology, the trackball uses optical tracking to precisely follow small flecks embedded in the large 55mm ball to provide smooth, accurate cursor control. The four buttons are customizable using our highly intuitive TrackballWorks software, while our award-winning Scroll Ring lets you quickly scan up and down web pages and large documents. Add it all up and you get exceptional comfort and ease-of-use that has set the industry standard for more than 20 years.
Product Description | Kensington Expert Mouse - trackball - USB - black | Device Type | Trackball | Connectivity Technology | Wired - USB | Colour | Black | Orientation | Right and left-handed | Movement Detection Technology | Optical | Buttons Qty | 4 | Features | DiamondEye technology, removable wrist rest | OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.8 or later, Google Chrome OS 44 or later | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Colour | Black |
Input Device | |
Connectivity Technology | Wired |
Interface | USB |
Buttons Qty | 4 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Included Accessories | Wrist rest |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Compliant Standards | FCC |
Software / System Requirements | |
Software Included | Drivers & Utilities |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
The following resources are available for the Kensington Expert Mouse Optical
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
