Kensington Expert Mouse Optical
£93.03
Delivery:
Key features
  • Award-winning Scroll Ring lets you scan up and down pages with ease
  • Detachable wrist rest cradles hand in comfort
  • Detachable wrist rest supports hand and wrist for ergonomic comfort
  • DiamondEye optical tracking technology for premium cursor control and accuracy
  • Large 55mm ball is designed as a perfect sphere to provide exceptional precision
  • Reliable wired USB connection
  • PC and Mac compatible
  • TrackballWorks lets you customize all 4 buttons, set cursor speed
  • Wired 180cm USB cable provides reliability and avoids need for batteries
  • Recommended Use: Mobile
  • Type: Trackball
  • Wired / Wireless: Wired
  • Colour: Black
  • Compatibility: PC
Product codes
Documents
The Expert Mouse Wired Trackball is the ultimate productivity enhancer that makes working at the desk quicker, more accurate and extremely comfortable for your hand and wrist. Featuring DiamondEye technology, the trackball uses optical tracking to precisely follow small flecks embedded in the large 55mm ball to provide smooth, accurate cursor control. The four buttons are customizable using our highly intuitive TrackballWorks software, while our award-winning Scroll Ring lets you quickly scan up and down web pages and large documents. Add it all up and you get exceptional comfort and ease-of-use that has set the industry standard for more than 20 years.
Product Description Kensington Expert Mouse - trackball - PS/2, USB
Device Type Trackball
Connectivity Technology Wired - PS/2, USB
Movement Detection Technology Optical
OS Required Microsoft Windows 98 or later, Apple MacOS X 10.0 or later
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 5-year warranty
Resources
The following resources are available for the Kensington Expert Mouse Optical
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Expert Mous...
£93.03
