Kensington InSight Plus Easel Copyholder - Charcoal
£7.68
Delivery:
Standard: 1-3 working days
Key features
  • Magnified line guide keeps eyes on-track
  • Collapsible for easy storage
  • Four angle settings for flexibility
  • Suitable for larger reports holding up to 50 sheets
  • Professional solution for referencing documents with vertical sliding rule
Product codes
The InSight Plus Easel Copyholder is designed to hold documents comfortably to reduce neck and eyestrain as you read or type. Four angle settings mean it can be easily adjusted for optimum use while it is flexible to hold up to 50 A4 sheets. Its magnified line guide also helps keep your eyes on track and it is fully collapsible for compact storage.
Kensington InSight Plus Easel Graphite - copy holder
Copy holder
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington InSight Plu...
£7.68
