Kensington Kensington Presenter Expert. Green Laser
£80.01
28 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 8GB Micro SD card stores presentations, fits inside wireless receiver
  • Backlit button controls move slides forward/back, black out screen and activate the green laser pointer
  • Comfortable grip with special contours for the hand
  • Cursor control joystick lets you use the presenter like a mouse, moving cursor up/down and left/right
  • Green laser pointer is 10x brighter than a red laser
  • Extended 150-foot wireless range to roam the room
  • Internal storage for wireless USB receiver so it wont get lost
  • Stock Status: In Stock
Product codes
Own what professionals use to take control of the room and a laptops cursor with the Expert Wireless Presenter Expert with Green Laser Pointer, Cursor Control & 4GB Memory. The presenter stores your PowerPoint or Keynote files on the 4GB Micro SD card that fits into the wireless USB receiver. With a simple flick of a switch, you toggle between presentation and cursor control modes. Make your point with a green laser thats 10 times brighter than standard red lasers, ideal for bigger rooms and LED/LCD screens. The highly reliable 2.4GHz receiver resists device interference and gives you control from up to 150 feet away.
Product Description Kensington Presenter Expert Green Laser Presenter with Cursor Control and Memory presentation remote control - black
Device Type Presentation remote control
Enclosure Colour Black
Localisation Europe
Connectivity Technology Radio
Max Operating Distance 50 m
Battery Pointing device battery
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Kensington...
£80.01
