Own what professionals use to take control of the room and a laptops cursor with the Expert Wireless Presenter Expert with Green Laser Pointer, Cursor Control & 4GB Memory. The presenter stores your PowerPoint or Keynote files on the 4GB Micro SD card that fits into the wireless USB receiver. With a simple flick of a switch, you toggle between presentation and cursor control modes. Make your point with a green laser thats 10 times brighter than standard red lasers, ideal for bigger rooms and LED/LCD screens. The highly reliable 2.4GHz receiver resists device interference and gives you control from up to 150 feet away.
Product Description | Kensington Presenter Expert Green Laser Presenter with Cursor Control and Memory presentation remote control - black | Device Type | Presentation remote control | Enclosure Colour | Black | Localisation | Europe | Connectivity Technology | Radio | Max Operating Distance | 50 m | Battery | Pointing device battery |
General | |
Features | Low battery alert, built-in laser pointer, back-lit buttons, built-in 2 GB flash memory, power on/off |
System Requirements | |
Operating System | Apple Mac OS, MS Windows 7, Windows 8 |
Miscellaneous | |
Included Accessories | Carrying pouch |
Power | |
