Kensington Kensington Pro Fit® Wireless Mobile Mouse - B...
Kensington Kensington Pro Fit® Wireless Mobile Mouse - Black
£21.73
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Comfortable two-button, scroll wheel design is ideal for mobile right-handed or left-handed users
  • Compatible with Windows and Mac
  • Plug & Play installation so you can be up and scrolling fast
  • 1000 DPI laser sensor provides high-definition tracking for enhanced performance
Product codes
When you need a compact, mobile mouse that offers wireless performance and comfort, the Kensington Pro Fit Wireless Mouse has everything you need to be productive. The 2.4GHz connection means there are no wires to worry about and the high definition 1000 DPI laser sensor lets you scroll around your screen with precision control. The two-button, scroll wheel design is highly intuitive and works equally well for both right-handed and left-handed users. And best of all, with simple and easy Plug & Play installation, youll be up and ready in no time after you plug in the nano receiver.
Kensington Pro Fit Mobile - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
9.64 cm x 5.8 cm x 3.3 cm
80 g
Worldwide
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
2
Movement Resolution
1000 dpi
Scrolling wheel, Nano wireless receiver, ambidextrous design, automatic power off
AA type
Apple MacOS, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Kensington...
£21.73
