When it comes to keeping your laptop performing at its peak, theres no better way than with the Kensington Laptop Cooling Stand. Featuring dual fans powered via a USB cable, the stand lifts the laptop off the desktop to promote better air circulation to reduce heat buildup, which improves battery performance and extends its lifecycle. The stand also has a retracting stand and four rubber stability pads to help keep the laptop stable.
Product Description | Kensington Laptop Cooling Stand - notebook stand | Product Type | Notebook stand | Colour | Black | Features | Tilt adjustment, USB powered, built-in 2 cooling fans | Manufacturer Warranty | 2-year warranty |
General | |
Colour | Black |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited warranty: - 2 years |
