Kensington LiftOff Portable Laptop Cooling Stand
£23.17
Delivery:
Key features
  • Portable notebook cooling stand helps keep your notebook running cooler, longer
  • Stand lifts the notebook off its surface, promoting air circulation and reducing heat buildup
  • Adjustable tilt and height lets you position the screen to reduce neck and eye strain
  • Lightweight and collapsible stand fits neatly into computer carrying case
  • Built-in handle design adds convenience and portability
  • Non-skid base holds notebook safely in place
Product codes
Keep your laptop running cooler and longer. The LiftOff Portable Laptop Cooling Stand lifts your computer off the desktop to promote airflow and reduce heat buildup, which improves the performance and life of the battery. Adjustable tilt and height settings allow you to put the screen where you want it, reducing neck and eye strain. The lightweight, collapsible stand has a built-in handle and fits into laptop carrying cases for up to 17 devices for fold-and-go portability. A non-skid base holds your laptop safely in place.
Product Description Kensington LiftOff notebook stand
Product Type Notebook stand
Colour Black
Features Tilt adjustment, adjustable height, carrying handles, SmartFit
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington LiftOff Por...
£23.17
