Kensington MicroSaver 2.0 Dual Headed Keyed Lock
£46.95
Delivery:
Key features
  • Carbon steel cable resists cutting attempts and anchors to desk, table or any fixed structure
  • Independently verified and tested for industry-leading standards in torque/pull, foreign implements, lock lifecycle, corrosion, key strength and other environmental conditions
  • Patented Hidden Pin Technology provides anti-pick features unique to Kensington
  • Strong 10mm twin lock heads offer uncompromised security for even the thinnest laptops and devices
  • Pivot and rotate ball joint provides superior laptop engagement
  • T-Bar Locking Technology attaches to the Kensington Security Slot found on most laptops and other devices like monitors, printers and docking stations
  • Register & Retrieve program allows you to order replacement keys
Product codes
The MicroSaver 2.0 represents the next generation of laptop security with a self-coiling cable that makes it ideal for highly mobile professionals. The MicroSaver 2.0 was developed using strict specifications and advanced technologies.
Product Description Kensington MicroSaver 2.0 Keyed Twin Laptop Lock security cable
Product Type Security cable
Package Content Cable lock
Product Material Carbon steel
Features T- bar lock, pivot adjustment, hidden pin, rotatable, kensington security slot
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington MicroSaver...
£46.95
