Kensington MicroSaver DS Lock
£52.88
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Register & Retrieve program allows you to order replacement keys
  • T-Bar Locking Technology attaches to the Kensington Security Slot found on most laptops
  • Ultrabook and MacBook laptops are valuable business tools, and desirable for thieves, but they are frequently too thin for a standard cable lock
  • Tamper-resistant, disk-style lock provides near-impenetrable theft protection
  • Carbon steel cable is cut-resistant and anchors to desk, table or any fixed structure
  • Pivot and Rotate cable hinge creates great freedom of movement and eliminates awkward angles for key insertion
Product codes
Ultrabook and MacBook laptops are valuable business tools, and desirable for thieves, but they are frequently too thin for a standard cable lock. The MicroSaver  DS Ultra-Thin Laptop Lock has a sleek profile to fit thinner devices and a rotating head to eliminate awkward angles when inserting the key.
Kensington MicroSaver Ultrabook Laptop Keyed Lock - security cable lock set
Security cable lock set
Silver
Product Material
Carbon steel
Length
1.5 m
T- bar lock, anti-shear
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington MicroSaver...
£52.88
