Kensington Monitor Stand Plus - Black
£45.66
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 3 height settings (3-to-6)
  • Extra-wide universal platform design fits any monitor up to 24" and 80 lbs
  • Stand positions monitor in line with your eyes to help reduce eye and neck strain
  • SmartFit System lets you adjust monitor height to your personal comfort color, by snapping risers into place
  • Type: Monitor stand
  • Stock Status: In Stock
Product codes
Trust the brand with 20 years of ergonomic expertise for a monitor stand that works perfectly in the office and for home office professionals. Kensingtons patented SmartFit System helps you position your monitor at the correct height without need for a specialist, reducing neck, back and eye strain. The extra-wide stand has 3 height settings and can fit larger monitors while leaving storage space under the platform to maximize your desktop surface area.
Product Description Kensington Monitor Stand Plus with SmartFit System - monitor stand
Product Type Monitor stand
Colour Black
Dimensions (WxDxH) 30.5 cm x 39.4 cm
Weight 1.71 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Monitor Sta...
£45.66
