Kensington Monitor Stand with Adjustable Shelves - Graphite
£24.70
Delivery:
Key features
  • Organise desktop and eliminate wasted space with keyboard storage and shelves
  • Height and twin side shelves adjust to customize workspace
  • Complements the sleek, contemporary design of flat panel displays
Product codes
Documents
One size doesn't fit all. When it comes to comfort, fit is everything.
Complying with ergonomic standards doesnt have to be a pain. The Kensington SmartFit system eliminates the complication, confusion and high cost of giving your employees safe, comfortable, ergonomic workstations. Years of research from the US Army revealed a direct correlation between hand size and body measurements. The result is a simple colour-coding system that allows users to adjust for the perfect fit in seconds, every time, leaving you to deal with more important projects.
SmartFit demystifies ergonomics for individuals making it easy to install and customise their workspace accessories to their ergonomic comfort requirements.
Every SmartFit product includes a hand chart in the box. This indicates the specific SmartFit colour setting that will deliver optimum ergonomic comfort for the user.
A small investment in workplace ergonomics can generate significant rewards in productivity by reducing fatigue.
Kensington Flat Panel Monitor Stand - stand
Stand
58 cm x 30 cm x 10 cm
Recommended Use
Flat panel
Recommended Display Size
Up to 21"
Resources
The following resources are available for the Kensington Monitor Stand with Adjustable Shelves - Graphite
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Monitor Sta...
£24.70
