Designed for laptops and devices with a Wedge lock slot, it meets Kensington's high standards for tamper-resistance, reliability and durability. Expanding side hooks grab on to the internal sides of the Wedge lock slot, creating a strong connection between the device frame and the lock to resist and deter theft attempts. A central pillar of Kensington's locking solutions, the exclusive keying system is common across all of Kensington's locks. Unparalleled custom management features provide flexibility, and anti-pick Hidden Pin technology offers complete peace of mind. Now IT directors will only have one keying system to manage across their organization. Offering the same level of cut-resistance and theft-resistance as thicker cables, the carbon steel cable with plastic sheath offers security and greater mobility. Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
Product Description | Kensington N17 Keyed Laptop Lock for Wedge Shaped Slots - security cable lock | Product Type | Security cable lock | Package Content | 2 x keys | Product Material | Carbon steel | Length | 1.83 m | Weight | 200 g | Features | Pivot adjustment, rotating, cut-resistant, hidden pin, 5mm Keying System, Tough Lock Head lock slot | Manufacturer Warranty | 5-year warranty |
General | |
Length | 1.83 m |
Thickness | 5 mm |
Weight | 200 g |
Security Cable Lock | |
Intended For | Notebook, tablet |
Lock Type | Wedge |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited warranty: - 5 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
